02-17-2023 03:25 AM
Hi im trying to display values to a table, is there any packages or ways to do this without creating alot of text fields? have alot of values to display
02-17-2023 08:37 AM
Currently WebIQ does not provide any table-like widget, you could however simply create a composite widget per line of the table-design and then use many of them to create a kind of virtual table layout.
02-17-2023 09:04 AM
If you are familiar with JS programming you can create the output dynamically via JS.
Can you give me more information, so may I can provide you an JS example.
02-20-2023 07:16 AM
right now data is taken from a OPCUA server, their measurements of sensors at various locations onthe machine. the customer would like to see the values visualised in a table, columns are the headers of sensor locations and time, rows are the values. i have maybe 16-19 columns and rows will constantly be added until a user input.
hopefully that makes sense 😅
thanks for the help again
02-20-2023 10:48 AM
So it's only for output of data, not input. On on vacation until friday, but than I can provide you an demo program, which should fix your requests.
02-24-2023 04:06 PM - edited 02-24-2023 04:06 PM
Here you find a demo prgram: HowTo-display-content-in-a-table
02-28-2023 09:04 AM
03-15-2023 04:58 AM
Hi been away from office for awhile will take a look at as soon as possible!
