04-14-2022 11:08 AM - last edited on 05-03-2022 05:22 PM by HmiGuide
I'm using iq-button-toggle and I would like to switch off the mouse hover function. The appearance of the button should not change. No matter if the status of the button is ON or OFF. I use this lines in a custom css file:
.iq-button-toggle.inverted:not(.locked)
.iq-button:focus,
.iq-button:hover,
.iq-button-toggle:not(.locked)
.iq-button:focus,
.iq-button:hover{border-color:rgba(60,60,60,.7);background-color:inherit;color:inherit}
This works when the button is OFF. But when the button is ON and the mouse is over it, the color changes. How can I modify the css file to get the correct behavior even when the state is ON?
04-26-2022 06:40 AM
I formatted your code:
.iq-button-toggle.inverted:not(.locked) .iq-button:focus,
.iq-button-toggle.inverted:not(.locked) .iq-button:hover,
.iq-button-toggle:not(.locked) .iq-button:focus,
.iq-button-toggle:not(.locked) .iq-button:hover {
color:inherit;
If you add "!important" after each of those colors it might work. or you could use more precise CSS selectors. Also see this for more info: https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
05-03-2022 10:48 AM
05-17-2022 02:41 PM - edited 05-17-2022 02:43 PM
You can use the following workaround, for the hover problem:
- Create two stylesheets of type iq-button-toggle
- e.g. TogBut_On and TogBut_Off
- Define the color and background color e.g.
.iq-button-toggle.TogBut_Off.iq-variant-01 .iq-button {
background-color: gray;
/* [Variant 01] - Toggle Button Label */
.iq-button-toggle.TogBut_Off.iq-variant-01 .iq-toggle-label {
color: blue;
- Select stylesheet TogBut_On, when button is on.
- Select stylesheet TogBut_Off, when button is off.
See link for info how to change color via stylesheets: https://developer.community.boschrexroth.com/t5/Smart-HMI-WebIQ-Designer-and/Change-the-color-of-an-...
Attached you find an example created with Designer V2.11.3
