10-13-2021 06:46 PM
How can a variable be inserted into a webIQ action, iFrame, etc.
For example, I would like to have an iFrame that updates based on a changing url. Is there a way to assign a string variable to the Source URL?
10-18-2021 08:32 AM
this is not possible directly because WebIQ uses a subscription model for all items thus you cannot use any arbitrary item name without subscribing it for a specific widget and unsubscribing it when the widget is no longer active or has been removed.
You can however create a LocalScript and change the iframe source URL whenever an item changes by subscribing to that item in the LocalScript.
Regards,
Sascha Kimmel
10-20-2021 10:19 AM - edited 11-07-2022 11:32 AM
Here is an example how to update the URL of a ifram via JS.
