How to read saved file with WebIQ and Js?
davifas
I am looking for a way to read a file that I saved previously through a javascript script in web iq.HmiGuide_0-1720076086994.pngI saved a txt file with FileManager's save function as you can see in the attached image. But once I have written, how can I read?
webiq-sk
Using its URL...
const fm = shmi.requires("visuals.session.FileManager");
         fm.save("my-text.txt", "This is some example text written to the file.", (error) => {
            if (error) {
                console.error("Error saving to file:", error);
            } else {
                console.log("Data saved to file successfully.");
         }, true);
This will save the file to '/my-text.txt': http://localhost:10123/{my-hmi-directory}/my-text.txt (Runtime) or http://localhost:10124/my-text.txt (Designer Preview Server).
HmiGuide
While a browser can't write to the Web server file system, there is the function FileManager.save() which you found in the WebIQ documentation.
Reading a file from the Web server is a basic and common function of the browser, therefore you do not need a special WebIQ function, just use common js script functions. Here is an example with XMLHttpRequest():
(function () {
  var actions = shmi.pkg("visuals.session.userActions"); //get reference to userActions object
  actions["readFile"] = function (p) {
    const sFileName = 'test.txt'
        let xmlhttp = new XMLHttpRequest();
        xmlhttp.open("GET", sFileName, false);
        xmlhttp.send();
        if (xmlhttp.status == 200) {
            let sRead = xmlhttp.responseText
            console.log("reading OK")
            console.log(sRead)
        } else {
            console.log("reading failed status=" + xmlhttp.status)
HmiGuide
While the existance of fs.write() function is a security issue, because you or anybody else can overwrite WebIQ scripts and other files. This function might be removed in the future. There are 2 alternative option to save data:
  1. Make the WebIQ variable(s) you want to store, Persistent
  2. Store the data via JS in a WebIQ recipe. The WebIQ API provides all function to do this. From creating a recipe template up to save data and read data from a recipe.
webiq-sk
"you or anybody else" -> by default only users in the "admin" group are able to do this.
