05-30-2023 01:51 PM
A couple of hours after powering the machine/CtrlX CORE i get the "Connection to server interrupted" notification in WebIq Designer. It is not possible to open the WebIQ Runtime Manager app on the core and I cannot reconnect with the WebIQ Designer. there is no exessive usage of CPU, Memory or network or anything.
I'm running WebIQ Designer v2.13.0 on Windows and WebIq Server App (Runtime App) 2.13.0 on the CtrlX CORE.
05-30-2023 02:40 PM
Please provide the log file from WebIQ's Runtime Manager on http://{CTRLX_IP}:10123
05-30-2023 04:57 PM
05-31-2023 08:26 AM
Although we haven't seen the error that the connection was interrupted (usually it just hangs) I assume this is the same issue as https://developer.community.boschrexroth.com/t5/Smart-HMI-WebIQ-Designer-and/WebIQ-runtime-gets-unre...
06-01-2023 09:36 AM
WebIQ 2.14 is now alvailable in the store. Please give here a feedback, if your issue is solved or not.
