09-08-2022 11:01 AM
I have an application with an XM21 with 2 axis syncronized in PLC with MC_Gear_in_pos function block.
If I put in this application 2 ctrlX Drive without core - controlled by XM21, can I syncronize in the same way with MC_Gear_In?
Thank you
09-09-2022 08:23 AM
If using the PLC function block in the mode "interpolation in control" it works. For details please address to your next regional support engineering team.
