selection of input and output
Drelax21
Hello everyone,
is there a way to get a biger selection of input and output variants?
I tried to change the inputs via the CSV file but this does not work.
thanks in advance for the reply.
6 REPLIES 6
georkueh
I'm sorry, but we can not identify the screenshot. Can you specify your questions and enlarge the screenshot!
kind regards
Drelax21
I am using the core as a device, but I need other data types such as INT, STRING.It would be easiest if I had 100-200 bytes of input and output to choose from.Unfortunately I can only select the ones in the picture
kind regards.
CodeWasi
the available types are - no others, not able to update to other range (as far as I know).
at least the InOut 64Byte worked between S7 and ctrlX as PNDevice. .... Faced troubles running other In/out with S7 before. See:
https://developer.community.boschrexroth.com/t5/CODESYS-PLC-Add-ons/codesys-profinet-communication/m...
georkueh
did you find a way to fix this issue?
kind regards
Drelax21
unfortunately not directly, we are now working with the 64 bytes in and out 'puts
Is this still an issue or can this topic be closed?
