12-12-2022 11:46 AM
The S7-1200 communicates with the CTRLX3 (XF51) profinet and cannot communicate normally. At present, it is unknown where the settings are incorrect or other situations. Does anyone know?
12-13-2022 11:08 AM - edited 12-13-2022 11:08 AM
Hello Hui,
faced similar topic some days ago and the rootcause in not finally closed and confirmed.
Could you please operate with a different PNIO Module testwise. The variety of moduels you can use is quite big - but I assume not all of them are supported right now (by the S7..).
Please configure the S7 and ctrlX-PLC with a PN-INOut64Byte and try to run the connection.
I checked several modules between ctrlX running as PNController and a 2nd ctrlX running as PN-Device and that worked unsuspiously.
Bye
Please add the PLC-Logger info with further infos regarding the test.
01-16-2023 08:23 AM
