WebVisu started on port 80, normal hmi not avaiable
AndreasL
For some reason the codesys webvisu suddenly started on port 80, thus making the normal HMI inaccessible.
Anyway to get around this?  Or do i need to reflash the core?
How do you change the port for the webwvsu in the PLC engineering, never found any settings for that).
/Andreas
5 REPLIES 5
AndreasL
I mangaged to get access to the web interface by excluding the webvisu from the PLC and downloading the application again.
But still doesnt explain how the webvisu ended up att port 21.
I forgot to add, using 1.14.1
Same problem here:
https://developer.community.boschrexroth.com/t5/CODESYS-PLC-Add-ons/CoDeSys-WebVisu-issue/m-p/56688#...
Unfortunately, there is no solution advice since then.
Dias
Hello Guys,
I made a short test with 1.12.3, her is my short summary:
At first you need a licence for your ctrlX CORE:
I create a small test programm with a small visu:
And at last you must know how you call the WebVisu I found this information in a CodeSys-Forum:
And it works also after a reboot
I think it should also works with Version 1.14
I hope this is helpfull
Please check behavior with RM 22.07 (version 01V16)! We found an issue regarding the order of the initialization of the ctrlX CORE Webserver and the CoDeSys one.
kind regards
