03-06-2024 06:53 PM - edited 03-06-2024 07:02 PM
Hello, I have purchased and loaded the PLC developer licesne but my ctrlx PLC installation is still not recognizing it. Is there something more I need to do?
03-07-2024 07:34 AM - edited 03-07-2024 03:42 PM
Did you buy the one from the Rexroth store? Then you need to do the same thing like with a ctrlX CORE but your PC. See FAQ for ctrlX WORKS.
Afterwards you have to install the Bosch Rexroth AG License Provider to the ctrlX PLC Engineering via the Add-on installer:
For general information see Quick Start Guide Licensing.
I will try to create an how to about it and also trigger the process to add information to the official online documentation.
03-07-2024 02:06 PM
03-07-2024 03:40 PM
You are right, the last step is missing in the FAQ. You have to install the Bosch Rexroth AG License Provider to the ctrlX PLC Engineering via the Add-on installer.
Also added this information to my post above.
