Codesys - Profinet Controller / PLC 1.20.4 - Library issue
ChrisLarkin
When using Profinet Controller 4.3.1.0 with PLC App 1.20.4 (both latest release) there are many errors cause by unknown type.
At least one library if not more are unable to be resolved causing 502 errors when trying to compile. Find at screenshot of a section of the CodeSys message window.
I have tried the following to no success:
  • Create empty project and build only with profinet controller and nothing else
  • Uninstall profinet add-on and all dependancies and then reinstall
georkueh
Hi Chris,
you are using the wrong PROFINET controller (CIFX). Please check the manual we provide!
kind regards
Okay, I see my mistake, thank you.
Attaching Ethernet then PROFINET to it has resolved my issue.
Hello
I need to develop a profinet - ethernet/Ip connection.
Could you help me, as I am using a COREX-M-X3.
@ANLH Please do not ask the same question in several forum. Your request is already being discussed in topic "profinet/ethernet ip communication (COREX-M-X3)".
