CoDeSys visu library
alink
I'd like to modify CoDeSys VisuDialogs for a WebVisu application
Where to find the library?
In CoDeSys - help the path is: "\CODESYS\Projects\Visu\Dialogs" - but where to find it with ctrlX Works?
georkueh
Hi, I do not understand your question. Do you want to patch the library VisuDialogs?
kind regards
alink
I'd like to modify it.
For example: own colors, no limit fields, bigger keypad
The same for numpad:
Numpad is bigger than keypad.
And if it is an Integer value then there shouldn't be a "."
Instead of OK a green OK or a red X instead ESC....
In CoDeSys help there is a description but I don't find the original, uncompiled library.
We are currently checking this internally.
