Add callable new dialogs
samkarshan
Hello
I was configuring codesys soft motion with 01V20  and following below link
https://developer.community.boschrexroth.com/t5/Store-and-How-to/CODESYS-Softmotion-How-to-configure...
But as per above link :i could not find settings related to new dialogs as below. what should be settings in these new dialogs while adding callable new dialogs in scheduler?These dialogs were not part of 01V16.
Thanks and Regards
Samkarshan V
7 REPLIES 7
The so called sync points were added to be better able to sort the running order of callables. See description of the dialogues and see documentation of the function.
Wee will update the description accordingly latest when 1.20 will release as LTS (long term service) version and will be delivered in standard ordering process.
samkarshan
I am not able to call callable as per document . I am getting error as below
What settings needs to be done- for soft motion to work?
The first pictures looks like there are spaces before and/or beside the argument. I just tested both possible methods in 1.20.0. Which version are you using exactly?
EDIT: Please check that there are no spaces, new lines etc around your argument.
Also check that there isn't already a PLC_EXTERNAL_EVENT with the same number is registered. I could reproduce your error message for that case.
  1. SyncPoints, call at the end of the task:
    1. Add callable to task - Define callable with sync pointsAdd callable to task - Define callable with sync points
    2. Add callable to task - After SyncPoints.pngAdd callable to task - After SyncPoints.png
    3. Add callable to task - BeforeSyncPointsAdd callable to task - BeforeSyncPoints
    4. Add callable to task - Finish with sync pointsAdd callable to task - Finish with sync points
  2. Run index, call at the beginning of the task:
    1. Add callable to task - Define callable with run indexAdd callable to task - Define callable with run index
    2. Add callable to task - Set run indexAdd callable to task - Set run index
    3. Add callable to task - Finish with run indexAdd callable to task - Finish with run index
Complete scheduler configuration: 
ctrlX CORE web UI scheduler configurationctrlX CORE web UI scheduler configuration
samkarshan
If "TASK_EXTERNAL_EVENT_01"is selected it works.
If ""TASK_EXTERNAL_EVENT_07" is selected as per documentation then it soes not work
EDIT: Added this remarks to my answer above.
samkarshan
How do you create "TASK_EXTERNAL_EVENT_07" now?
I am able to create only "TASK_EXTERNAL_EVENT_01".
Main problem here was that there were old settings in the scheduler that prevented the creation to work. We reset the scheduler settings via posting "{}" to the data layer node "scheduler/admin/cfg/reset-programs". Afterwards added the EtherCat master callable to the task configuration by hand, as it did not automatically, and everything worked again like expected.
