06-30-2021 09:08 AM
Hello together,
I created a programm in the IDE visual coding. The program works fine. But if the projects gets larger, its not posible to compile it anymore. The IDE don't show a mistake. Whats the problem here? Is there a limit for the size of the program?
Greetings
Yannic
06-30-2021 11:00 AM
There are two possibilities that could cause your problem:
It would be good for us to check the code you are using. Please send me a private message with your contact data so we can get in direct contact.
07-01-2021 11:09 AM
I found one topic how to break compiling:
If you are using the IPC extension and you added more then one application with the same name there is an ambiguity that the compiler cannot handle. Please check that in the project settings:
