12-03-2020 09:10 AM
As a standard setting inside the ctrlX I/O Engineering the user only can see the setting of the process data:
But how the user can add additional parameters?
12-03-2020 09:13 AM
At first, the user has to enable the expert setting on tab General:
Then new tabs will occured and then it's possible to add new parameters to the process data:
12-03-2020 02:29 PM
...but the parameters S-0-0134 and S-0-0135 have to be on top (first entry)
