C0373: Device does not support alignment setting of image used in button
Qeslo
Is there a way to avoid the following warning?
It is created for each button that includes an image.
Due to those warnings it is easy to loose track of important warnings
HmiGuide
I can't find the section "Image settings" in a button with PLC Engineering 1.20.3. Which ctrlX version you are using?
I would try to change the setting to the default value, expecting that the warning disappears.
For PLC code there is an attribute to disable warnings (https://help.codesys.com/api-content/2/codesys/3.5.14.0/en/_cds_pragma_attribute_warning_disable/), but I don't know if this is possible for visu, too.
HmiGuide
In the "Project/Project Setting.../Compiler warnings" you find a list with warning, which you can disable. Your warning is listed there, too.
