11-22-2022 02:45 AM
Can you use the codesys C-Integration component to develop in C language in ctrlx engineering.
11-22-2022 08:28 AM
in ctrlX PLC Engineering it is supported, but not with ctrlX CORE devices. Currently we are working on a solution.
kind regards
11-24-2022 04:16 AM
If the customer has used MATLAB to generate C++or C code to control the motion of the motor, now ask Rexroth whether it supports the import of library files into C++or C code. What functions and licenses are required? Do we have such cases.
Thank you in advance.
11-24-2022 11:29 AM
Hello JHU1XI1,
on the SPS fair this November we showed live a tool chain for model-based software development (see the added presentation slide we showed). With this it is possible to generate an app for ctrlX CORE by pressing only one button in MATLAB/Simulink. This tool chain will be available as a product in March 2023.
Please write me a private message if you are interested in a discussion aboout the concrete use case of the customer.
