App Build Environments not booting, ubuntu-20.04-server-cloudimg-amd64.img missing
joeG
I get the attached message when I try booting the App Build Enviroment in ctrlX Works 1.14.1. The file ubuntu-20.04-server-cloudimg-amd64.img is located at the URL reference in the message (https://cloud-images.ubuntu.com/releases/focal/release/). I am now able to boot, but I am confused about why I needed to do the extra step.
Jochen_Mueller
Hello
this problem occur at ctrlX WORKS 1.14 if you don't have the right to start powershell scripts at you PC.
With ctrlX WORKS 1.16 the creation of the Build Environment is solved in a different way. So you will not get this message again.
Jochen
As a workaround until 1.16 you can change the script to resolve this issue:
REM
REM Helper script to download an img file.
REM
rmdir /S /Q img 2>nul
mkdir img
echo Downloading %1 ...
Powershell Invoke-WebRequest %1 -OutFile img\%2
move img\%2 .
