I try to set up a project consisting of first XCS, with in total 23 axis on DC bus, and a second XCS with in total 9 axis on DC bus. I discover lot of problems, pls check out project ID CTRLX1062918 for reference.
- Pls make possible to group elements, for coordinated placing in the grafical view. Otherwise you will not get overview, in case you started in unideal positions
- make possible to group elements for duplication
- the interaction with the Configurator is so slow, every action takes several seconds to be performed. So time you do not even know if the Configurator is still running or not. I tried out in Firefox and Chrome as well.
- To connect 2 products, you need a lot of clicks, provide some function to make possible a sort of a list configuration of redundant tasks
- XNF Filter can be choosen for that XCS - I know this is not sufficient for this number of axis - there is no chance to deselect XCS nor to insert a HNF
