12-18-2020 11:10 AM
how is it possible that only limited persons are able to look into a configuration?
I got the folowing message
12-18-2020 11:17 AM
Moved to area ctrlX SERVICES.
12-18-2020 03:47 PM
Hello, configuration projects are stored in ctrlX Configurator using unique IDs. In general only the creator has owner rights and has access to his configuration projects. This ensures that even if a project ID is known, other users cannot open an external project. Via the project management configuration projects can be set as "public" for the access by other users.
Find more information on the management of projects within ctrlX Configurator in this blog.
