09-20-2022 10:51 AM - last edited on 09-21-2022 08:42 AM by CodeShepherd
I have a bit of similar problem with the PLC.
Safex C15 is appearing to the datalayer realtime, but I can't add it to the PLC (nothing happens when I try to move it on the PLC project).
All other devices are possible to be moved on the project. Only workaround is to select 'Insert all data to ctrlX Core again', but it gives error (see the image) and all data is unusable on the Safex.
I'm using PLC engineering version 1.16.1 and I have been able to do these steps before, but now something seems to block it.
09-21-2022 08:43 AM - edited 09-22-2022 11:08 AM
Moved this thread to own topic from this post.
09-22-2022 02:05 AM
Hello CodeShepherd,
you refer to a problem with a mismatch between ESI and data layer. This (Polygon's case) sounds or could be different. I'm not sure that it is related to ctrlX SAFETY but could be ctrlX PLC or CORE subject.
Hello Polygon,
can you please provide more detailed facts like ...
Best regards
ctrlX SAFETY Team
11-23-2022 09:49 AM
Any news here?
