Is it possible to reset a Safex from ctrlX Core via Ethercat?
Also, I tried with the Start/Reset block and it works with a button:
But I need without physical button. Is it possible via filedbus from ctrlX Core??
Thanks!!
a week ago
Hello @joelfernandez ,
It is possible to reset from ctrlX CORE but not directly. What I mean by this is you would have to send a bit from ctrlX CORE via Functional exchange (EtherCAT) to SAFEX. Then link this bit to a SAFEX output that is wired to a SAFEX input defined as Start / Reset like you did with the physical button.
The other ways to reset are:
HTH
