1) When I try to opne the ctrlXPlcEngineering the process never ends.
2) So I tried to repair the installation and I get the attached error report.
3) I tried also to uninstall the ctrlXWorks. and install it again => Same behaviour than 1)
Could you help me please
in ctrlX PLC Engineering (WRK-V-0118.2) the VisualElemRepository Assembly is installed in Version=4.2.0.0.
Can you try to clean the PluginCache files (C:\ProgramData\AP\PlugInCaches\StudioPlc-*.cache)?
Did this solve your problem? If not, can you provide some more information when the crash dialog appears, did you do a clean new installation or did you install additional packages. How did you start the ctrlX PLC Engineering (Shortcut or via ctlrX WORKS?)
Regards, Oliver
