ctrlX PLCopen library Ladder Error
Open
Hello Community,
I am using ctrlX drive demo unit with PLCopen library ladder programming,
When i used MC_Power function block whenever i logged in it will show Error, i tried resetting Warm, Cold and Origin still the same.
But however when i use structured text it has no issue.
Anyone encounter the same issue?
please see attached.
Which versions of the ctrlX PLC Engineering, CXA_PLCopen library and ctrlX PLC app are you using?
The error tels us that the input is wrong. I can confirm this behaviour (Version 1.12) as long as the AXIS_REF is not set correct. But it is working fine when set correctly:
ctrlX Motion axis CXA_PLCopen.MC_Power LDctrlX Motion axis CXA_PLCopen.MC_Power LD
Hello CodeShepherd,
I am using ctrlX PLC version 1.14.1 and CXA_PLCopen library 1.14.0.1
This error only happen sometimes and sometimes after a power cycle it worked normally.
I tried to replicate the error however it works fine now.
