08-23-2022 01:00 PM
while debugging this message does appear. It's really annoyoing, is there a way to turn this off?
08-29-2022 07:33 AM - edited 08-29-2022 07:34 AM
This error appears when you try to jump into a compiled (closed) library, for which you do not have the corresponding open code. You have to "step over" instead of "step into" then you will not see this.
Could you tell us your ctrlX PLC Engineering version and which language is set?
09-02-2022 09:08 AM - edited 09-02-2022 09:09 AM
I use ctrlXPLC 1.16.1 - German language
Thanks, I think I have to use F10 instead of F8 like in IndraWorksV12
