12-09-2021 06:36 PM
I have been asked why the ctrlX PLC Gateway icon flashes in the system tray when ctrlX PLC or ctrlX WORKS Engineering are not open. This is with installed version 1.10.4. Please see the attached video and advise.
Thank you!
12-10-2021 02:27 PM
Hello, I think on your computer are several installations of IndraWorks, ctrlX WORKS and /or CoDeSys. Each software provides his proprietary Gateway. The blinking results from the coexistence of these gateways. Up to now we were not able to identify the root cause for this issue. But in any case the blinking is not critical or indicates any errors. Is this understandable for you?
kind regards
