Read/Write XCS drive parameters in PLC Engineering
MaxS
I am new to the CtrlX Automation platform, I need to read/write parameters of a XCS drive in a PLC program developed in CtrlX PLC Engineering. Such program will be downloaded and executed on the drive itself, so when I create the  program I select the template ctrlX Drive Technology Function.
What is the most simple and efficient way to read/write parameters of the drive from this program?
I found the function blocks IL_DriveReadParameter and IL_DriveWriteParameter in the library CXAD_DriveParameter. They require a variable of type DEVICE_REF as input, but I do not understand how to associate such variable to the drive, is there a link to do? Do I need to use CtrlX IO Engineering?
Thanks.
Best regards.
joeG
CXAD_... libraries are only useable for drive technology functions. They do not work in a ctrlX CORE. You have to use generall libraries CXA_... or control only libraries CXAC_... See how to "Ethercat SoE: Read and write ctrlX DRIVE and/or Indradrive S and P parameters".
