How can we set the system time of the ctrlX CORE out of a PLC program?
I've tried the SysTimeRtcSet function block (SysTimeRtc library) but this returns "ERR_NO_ACCESS_RIGHTS".
Thank you in advance.
Is there a plan to have a possobility to set the time via a PLC Programm with an PLC Function Block?
Hello Maurus,
currently there's no plan. But you can create a customer issue as requirement.
kind regards
Is it possible to issue the put command from the PLC application?
