CXA_SocketComm TCP
CXA_SocketComm TCP
Open
Hi Community,
I am new to using CXA_SocketComm TCP.
I manage to established connection from ctrlX to a TCP device. However i did not receive feedback from the device after sending a string. (see attached)
Looking for advice.
Warmest regards,
Open
How to test if my TCP client is working?
Are there tools to host TCP server on my engineering PC and try sending a string from my ctrlX to my TCP server hosted on my engineering PC?
Warmest regards,
I created some examples for communication via TCP between ctrlX CORE and ctrlX COREvirtual. See "Communicate between a ctrlX COREvirtual and other applications [DOCU]". There I am using Node-RED but PLC works in a similar way.
Which function blocks exactly are you using in your example? Normally you have a TCP server on one side permanently running and a client connected to it waiting for getting data.
Open
Hi CodeShepherd,
I am using IL_TCPConnectionAsync function block library.
Thank you for your tip we tried setting up TCP communication in Node-red, connection is established however when we attempt to send a string it did not send to the device and no feedback from the device.
We solved it by using Telnet communication in Node-red. It is unsure why it is behaving this way.
JordiLaboria
Good morning, not if this is what you are commenting on. I pass you a document on communications in general and another on communication between XM and ctrlX Core in NodeRed using the IL_TCPCyclic module
Best Regards
Jordi Laboria
E-Mail: jordi.laboria@boschrexroth.es
DCET/SLF4-ES
