The CXA_OpcUaClient library contains a CodeExample.zip file. Ho do get access to this zip file? I don't have a context menu t.e. to save this file. I think normaly it's possible to double click this element, but nothing happens in my case.
I'm using PLC Engineering v 1.10.1
One workaround is to open the library in an very early ctrlX version or use IndraWorks. In this versions, you can access the included zip files
