limit of commandos used for a contour
SpoonMan
Hi CodeSheperd,
Is there a limit to the number of commands used in a contour? I need to issue over 2000 moves from a custom points table...
Moved to own topic from "ML_KinPolyTransP and ST_CONTINUOUS_SLOPE".
Which version are you using? In general the available memory is the limit but from version 2.6 there is a setting "motion/kin/<name of kinematik>/cfg/prep-limits/max-cmds-in-buffer" capable of limiting, preventing the system from crashing when out of memory. But 2000 commands are no problem at all.
I am using 2.6. I will try to adjust this value and see what happens.
