Is it possible to replicate S-0-0108 (Feedrate override) with ctrlX core motion?
What do you mean with replicate?
The Parameter is still present in the drive.
In the ctrlX MOTION there is the command "ML_SetOverride" for each motion object like an axis or kinematic to set an velocity override. See online documentation.
Also an "ML_SetAccOverride" is available to set an acceleration override. See online documentation.
Since the ctrlX now uses position control instead of drive controlled positioning S-0-0108 is no longer useful with the ctrlX. That answers my question, I will give that a try, thank you.
