09-20-2024 10:08 PM
I have a FlexProfile in which the follower axis advances 5 degrees over a 360 degree master cycle:
With ProfileEntry=SLAVE_ORIGIN_MASTER_ORIGIN, SwitchPosition=0 and SwitchProfileOnPos=TRUE, the FlexProfile completes its cycle normally when the OpMode is retriggered.
However, under the same conditions as above, any changes to SlaveOffset take immediate effect:
Is this the intended behaviour? Is there any way to postpone the application of the SlaveOffset delta until the end of cycle?
Same question for MB_CamIn, which behaves similarly.
ctrlX CORE 3.2.x. ctrlX PLC Engineering 3.2.0. Motion and PLC apps 3.2.0.
09-25-2024 03:13 PM
This is a known topic and already addressed internally. Changes are planned for version 3.6 coming up in April 2025.
