IDE Visual Coding
IDE Visual Coding
Hendri
Hi all,
I wrote a little 3 Axis kinematic program. I am using IDE version 1.10.12 and also ctrlX Works 1.10.4 and also version 1.12.2
When I try to debug the program it comes up with the following error.
When I try and run the program it comes up with the following.
This happens when I run it in both versions of ctrlX Works.
The PLC program works great and all axis are running, but I just have a problem with the IDE app.
Can someone please assist?
Kind Regards
Hendri
Did you reset your app data? Please check if the folder scripts is still present on your ctrlX CORE:
scripts folder in app datascripts folder in app data
It only has "Script" in the app data. I have reset the app data and set up everything from scratch three times now with no luck of it working nor writing the "scripts" folder in there.
Any advise with what I can do?
Kind Regards
When resetting the app data the folder "Scripts" will be deleted and IDE is not longer working correct. You could now:
  1. Get this folder from an saved app data archive and load the data to the actual active app data.
  2. Uninstall the IDE app and install it again to create the folder.
Works Perfectly.
Thank you for your assistance.
Kind Regards
