02-17-2022 02:56 PM
When grouped into a kinematic one of the axes has an excessive deviation fault. After this, the axis can no longer be enabled without generating the ecessive deviaiton. It can be enabled and jogged from the drive software. Here is a scope of the commanded position from the controller after the fault occurs.
02-18-2022 09:12 AM
Could you please confirm:
Normal behavior:
