05-13-2024 09:09 PM
I am working with a customer on an application that is sensitive to the direction of synchronization. The final position of the synchronization determines if the synchronization should occur as positive, negative or shortest path with a flexprofile. Is there a way to determine the target position of a flexprofile before synchronization occurs based on the master axis position?
05-15-2024 10:43 AM
Hello Alex
Currently it is not possible to get this information. We already have set a requirement at our development department. The realization is planned somewhere in 2025.
Jochen
