Deleting\Removing axis profiles
ctrlXProgrammatore
I am having troubles permanently removing an axis profile. I am using version V1.10.4 (RM21.07). I delete it but after rebooting the core it comes back.
Profile_2 appears to be removed after putting the motion back to operation mode running but comes back after reboot\power cycle:
I noticed before the last reboot\power cycle that the Profile_2.json file is still in the app data. I am guessing this is why it comes back since it is really not deleted. Is there a way to remove this without doing a complete reset of the app data? I would rather not have to rebuild the axes, kinematics, and profiles again but if I have to I will. Is there a way export the individual configurations and then import them after a reset? This way I would only have to redo the axis profiles:
Thanks for mentioning. I can confirm that behaviour and we will investigate it.
The easiest way would be to click on "Save to archive" in the manage app data area. This will trigger a save of the actual configuration and your deleted axis profiles will be gone.
Thank you! That was an easy fix.
the bug was fixed with RM 21.11 (V1.12).
Michael
