Persistent variables in NodeRed
David08
Is it possible to make the flow and globals persistent variables in a NodeRed program (keep value on reboot)?
I have seen some tutorial in the NodeRed documentation, with context variables but it forces to modify the settings.js file which is not in the NodeRed directory.
Working with context : Node-RED (nodered.org)
Any ideas?
Thanks.
Sgilk
Contributor
Local file system storage is enabled on the ctrlx Node-RED distribution. Every 60s the Node-RED file context is saved to the Node-RED app data /context directory.
    contextStorage: {
        default: 'memoryOnly',
        memoryOnly: {
            module: 'memory'
        file: {
            module: 'localfilesystem',
            cache: true,
            flushInterval: 60
 You can write values using the change node. Example below.
