03-23-2023 07:45 AM
Hello Community,
We have 17 brand new ctrlX unable to install Node-Red pallete. (see below)
We are getting error "Failed to load node catalogue" for all 17 units.
We tried version 1.16 and 1.18 but still no avail.
I have tried our demo unit is working fine but the brand new ctrlX has issue.
Anyone had this issue?
Attached is the system report.
Warmest regards,
03-23-2023 07:55 AM - edited 03-23-2023 07:59 AM
Hi Open,
Please beware that your ctrlX CORE has to be connected to an open internet to be able to download a palete in Node-Red. Besides your ctrlX CORE, also your engineering PC has to have internet connection. Please also take a look into the date and time settings on the ctrlX CORE, to see if the time is set correct, this can also be an issue.
This community member also had a similar problem: Node Red issue installing palete.
03-23-2023 09:13 AM - edited 03-23-2023 09:14 AM
Hi Nick,
Thank you for your reply,
I have resolved the installation of node issue,
I am using bosch laptop therefore i do not have access to internet. i then use another pc with internet access and it worked.
I am facing another issue, i can install Influxdb and Modbus node except node-red-contrib-aedes.
When i use localhost node-red and install node-red-contrib-aedes 0.11.1 it can install but in ctrlX i could not install.
When i use my demo ctrlX unit i cant update node-red-contrib-aedes node from 0.9.0 to 0.11.1
Anyone is facing this issue?
