10-28-2022 03:47 AM
I am currently using a sensor that publishes data via MQTT to a HiveMQ MQTT Broker.
From ctrlX Node-RED app I created a HiveMQ MQTT Broker and used the mqtt subscribe node to subscribe to the topics and created a simple monitoring dashboard.
Next, I wanted to try to visualize the sensor data in webIQ but the problem is webIQ is using OPC UA, and the sensor data is not available in OPC UA/ ctrlX Data Layer.
Is there any way we can publish the data from MQTT (either from Node-RED or Cedalo MQTT broker) to OPC UA/ ctrlX Data Layer?
10-28-2022 09:28 AM - edited 11-02-2022 07:11 AM
Hi ahmadkhairi,
we will release this function also as a ready made app soon, so you, or your customer, don't need to build your own app like described below.
10-28-2022 03:13 PM
@ahmadKhairi I have been accomplishing this using a custom Python app which registers nodes on the datalayer. You can then write to these via Node-Red and read them over OPC UA in WebIQ.
10-31-2022 03:15 PM
hi.. Thanks for the suggestion. Haven't tried running python scripts with the ctrlX Core yet. Maybe will give this a try soon
11-12-2022 04:32 AM
