05-28-2024 07:41 AM
Hi Community,
I am new in using ctrlX IO XI522001 RS485 Serial Comm, i cant find much information about this module.
Has anyone tried it with PLC program example?
Warmest regards,
05-28-2024 08:38 AM
allo,
you can use the function block for the communication module.
In the library is also an example program available.
The communication parameters are CoE parameters. You find this in the CoE part of the module:
The documetation is at the moment not finish.
05-31-2024 09:09 AM
06-03-2024 12:58 PM
Hallo Open,
here the wiring for RS485
And here the wirinh for RS422
Regards,
a month ago
Does this ctrlX IO XI522001 module support ModbusRTU (RS485)?
a month ago
Hallo,
yes this module support ModbusRTU. There is a library for the ModbusRTU communication available.
a month ago
Hi @Sozu ,
The ModbusRTU (RS485) communication PLC library, can i use the how to's method CXA_MODBUSRTU library?https://developer.community.boschrexroth.com/t5/Store-and-How-to/Various-methods-to-use-ModbusRTU-RS...
4 weeks ago
Hallo,
you need a special library for the ctrlX IO module. I organise the appropriate library for you.
4 weeks ago - last edited 4 weeks ago
3 weeks ago
Thanks Everyone for reply!
I finally got it working!!! 🙂
