2 weeks ago - last edited 2 weeks ago
Good morning Rexroth forum,
I am new to the Rexroth platform and have been working closely with our aftersales rep to get me up to speed. Figured Id reach out here before bugging him again.
Im using an X3 controller, have the IDE installed on my engineering PC and all the licences were purchased and installed by our rep. Im running into an issue with trying to configure my Ethercat Master app. When I open it up I get 404 message. I did some searching and found that maybe my dependcies for the app arent up to date? Im not sure so I have included a screen shot of what Im looking at.
What do I need to do to remedy this?
Thanks,
Thom
2 weeks ago
Hello @ThomFearn ,
You are correct that this is a dependency mismatch. You can see in your second image that you have system apps v1.20 and have installed v2.6.3 of the EtherCAT master application. You have two options...
In either case, the applications can be found in the collaboration rooms.
2 weeks ago
Hey Sgilk,
I just downgraded my EtherCat master to v1.20 as you mentioned and I can now configure the node. Thank you for your assistance.
2 weeks ago
Hi Thom,
It looks like you're using a different version. You need version 2.6 instead of 1.20. You can download the required version from the Collaboration Rooms.
Basically that the core system image is separate from the apps installed on it. This means you can either update the core to version 2.6 or install the version 1.2 apps on the current core system.
Hope this helps.
@Sgilkehall wrote:Hello @ThomFearn ,
- Upgrade your system applications to v2.6 to be compatible with the currently installed EtherCAT Master
- Downgrade your EtherCAT Master to v1.20 to be compatible the the currently installed system applications
My application also not worked. Your answer is very helpful. Thanks
