11-23-2022 09:32 AM
What is to know about interims handling regarding RM2111 ctrlX-IOEngineering effects on modular ECAT slaves?
12-06-2021 03:25 PM
Fix is not released yet - available soon, but in meantime please consider the following workaround:
Fact: ctrlX-IOEngineering (released by RM21_11) does not support the configuration of a few modular slave.
Identified devices :
● ctrlX SAFETY
● ifm AL1x3x (e.g. ifm AL1930) but potentially others might be affected.
What does the malfunction look like?
E.g. running "Scan for device" - will not identify the affected slaves correctly ( Unknown device... ).
Workaround : Import into the ctrlX-IOEngineering (RM2111) the projectarchive which was created with former (RM2107) version. Verify that the related device-data is included in the projectarchive file. Save and extract examplarily like below.
In case the WorksVersions are not available (anymore) - the collaboration-room still offers RM2107-Works and installing in parallel is recommended (choose 'New Installation' instead of 'Update-I.')
The workaround does not require any changes to the ctrlX environment (Apps etc stays the same).
Please note that the behaviour is documented in the release-notes of RM2111 already.
Further details available in chapter 3.3.2 ctrlX IO Engineering
