01-17-2023 09:50 PM - edited 01-17-2023 09:52 PM
Hello folks,
Just wondering here if it is possible to have the CtrlX-Core controlling a Keyence Stepper Drive. The drive model is QS-10P and the motor model is QS-M60.
My concern here is if it is possible to use the S20-PWM modules connected beside a S20-EtherCAT bus coupler. Having the CtrlX-Core as EtherCAT master here.
If the S20-PWM does not work, another approach would be having the CtrlX-Core as Profinet master controlling a R-IB IL Profinet bus coupler and the R-IB IL-PWM module.
My oher concern would be the RIL_InlineIOModule library, is it possible to install it in the CtrlX-Core?
Which way should I go here?
I have also added this question in the Controls Forum thread below:
https://connect.bosch.com/forums/html/threadTopic?id=a2d9e723-d3e5-4015-91fb-44feea69588a
Thanks a lot.
01-18-2023 10:36 AM - edited 01-18-2023 10:37 AM
Please see this topic for which S20 modules can be used at ctrlX CORE with S20-EC bus coupler.
