Hi Community,
I am using WR2107 CtrlX HMI,
Using the kiosk setting to set auto launch and lock codesys webvisu webpage when startup.
When i turn on the CtrlX and CtrlX HMI the Webstation app could not refresh the web page. It required Kiosk password to refresh the webpage.
Is it possible for the user refresh the webpage to display codesys webvisu without the Kiosk setting password?
Warmest regards,
Open
I've got the same issue and no solution instead of switching off/on, any other thoughts?
I have this quesiton too. The codesys WebVisu takes to long to boot. Hopefully there is a script that can delay this?
The idea of a delayed start is quite good.
I don't have any experience with Android, but is it possible to write a .bat - file (or something) which starts kiosk mode as a delayed task action?
With Windows it is possible to create a task with a delay of xxx seconds/minutes
I have the same issue. At the moment we will delay the start of the HMI until the CtrlX Core is in Run mode.
Still, is there any chance it will be solved by the app in the future ?
Hi.
Is there any info on possible fix for this issue in the future? Or maybe has somebody done some kind of work around solution?
