05-06-2020 10:26 AM
How many extended encoder interfaces are available if using a MSK motor + external encoder? |
05-07-2020 07:47 AM
Only in a single axis drive are two “EC” interfaces are able to configure.
05-07-2020 09:20 AM
In a double axis drive as well the first axis may have a 2nd "EC" encoder. Means:
- both axes always have the digital encoder interface present to allow the evaluation of AcuroLink encoders present at MS2N motors
- both axes have an additional multi-encoder interface for each axis if ordered with option "EC" at type code field 20 and 21
- 1st axis incorporates an additional multi-encoder interface if ordered with option "EC" at type code field 22 and 23
Only two of these encoders may be functional for each of these axes.
