01-19-2024 09:46 AM
Hi Community,
Is it possible to configure ctrlX Drive Local I/O (XG31) to ctrlX PLC global variable like IndradriveCS MLD function? I see that ctrlX Drive Local I/O do not have this option.
IndradriveCS Local I/O:
ctrlX Drive Local I/O:
Warmest regards,
01-19-2024 03:44 PM
The PLC variables will only be visible if the TechFunc function (TE1, TF1, TX1 or TE0) is active. In your case this is not yet the case. You need to properly license and then activate the TechFunc functionality in before.
