06-26-2023 10:41 AM - edited 06-26-2023 10:43 AM
In the ctrlX drive I like to have the scaling in mtr/s andor mm/s^2.
I get an error message when changing the scaling from min to s.
Above its in Degrees. Then its accepted. But if you cange over to Linear this error pops up.
IDN not supported!
I test this in 03V08, but at the floor we should have 03V16. But I will check that.
Is this a known thing? Now I have to use a speed of mm/min
06-27-2023 07:10 AM
If set correctly it should be possible to set the units to e.g. m/s. Using what firmware version shouldn´t matter. See:
If you need further help send your parameter file in format "all parameters" for detailed check.
06-27-2023 09:24 AM
Hello Drive_U
If I change it in the "scaling extended" view then it is accepted and changed.
After that its also changed (and accepted) in the default scaling dialogue.
