Hi
Can the serial setup function as well be used with ctrlX DRIVE?
Because I did see it in the tools window in the presentation.
It depends. Serial commissioning via the iwdc commandline tool currently supports up and downloading parameter files and downloading the firmware as fwa file.
Doing a setup with reseting parameters or activating an SMO image is currently not supported.
The UI tool SerialSetup currently doesn't support ctrlX DRIVE
