Serial Setup function
WeisCh
Hi
Can the serial setup function as well be used with ctrlX DRIVE?
Because I did see it in the tools window in the presentation.
Drives_Uwe
Re: Serial Setup function
Yes, serial setup is working as well with ctrlX DRIVE.
PhilippSeith
It depends. Serial commissioning via the iwdc commandline tool currently supports up and downloading parameter files and downloading the firmware as fwa file.
Doing a setup with reseting parameters or activating an SMO image is currently not supported.
The UI tool SerialSetup currently doesn't support ctrlX DRIVE
